MMOexp ARC Raiders: Entering the Security Wing
Улучшение и адаптация ВЭЖХ методик. Разработка и помощь в освоении методик. Тестирование колонок. Валидация и квалификация оборудования.
Сообщение Stellaol » Ср апр 08, 2026 7:27 am
If the batteries aren't upstairs, check the lower room beneath the lobby area. At the end of ARC Raiders Coins a row of filing cabinets, you may find all three battery cells grouped together.
Regardless of which location they spawn in, all three batteries will be in the same place, so you won't need to search the entire facility.
Once you've found them, carry each battery back to the locked door and insert it into the slots to open the Security Wing.
After installing all three battery cells, the shuttered door will open, granting access to the locked red room inside the Security Wing.
This room contains several pieces of valuable loot, but the most important items for the quest are related to Project Heartwood.
Be cautious when entering. Because this location contains good rewards and a quest objective, other players may also be searching the area.
Finding the Project Heartwood Records
Inside the locked room, head toward the back-right corner.
Here you'll find an interaction prompt allowing you to play a recording. Activating this prompt will power up the monitors located at the front of the room, revealing information tied to Project Heartwood.
Interacting with this recording fulfills the quest step requiring you to search for Mantikor's research records.
Locating the Dusty Film Reel
After activating the recording, move to the front of the room where the screens are located.
Nearby, you'll find a cabinet that can be searched. Inside this cabinet is the key quest item: the Dusty Film Reel.
Pick up the reel immediately after locating it.
To protect it from being lost if you die, it's strongly recommended to place it in your safe pocket. Doing so ensures the item remains in your inventory even if things go wrong during extraction.
Escaping and Completing the Quest
With the Dusty Film Reel secured, your final objective is simple: extract from the match and deliver the reel to Shani.
Because all quest steps must be completed within one run, survival is critical at this point. Avoid unnecessary fights and prioritize reaching the nearest extraction point safely.
Once you return to base, speak with Shani to hand over the film reel and complete the "A Dead End" quest.
Final Tips for Completing "A Dead End"
This quest can feel overwhelming the first time you attempt it, but a few simple strategies can make it much easier:
Learn the Reinforced Reception location before entering the match
Move quickly through the underground facility
Check both battery spawn locations
Store the Dusty Film Reel in your safe pocket
Avoid combat when escaping
Because everything must be completed in a single round, preparation is key. Knowing exactly where to go allows you to finish the quest quickly and minimize the risk of running into other players. The right cheap ARC Raiders Materials can be very helpful.
Stellaol
Вернуться в Дополнительные сервисы и услуги
