MMOexp CFB 26: Zone Drops for Long Passes
Обучение методу ВЭЖХ. Программы и расписание ежемесячных обучающих курсов. Выездные курсы. Фотоотчеты прошедших курсов
Сообщение Stellaol » Ср апр 08, 2026 7:26 am
If you've played competitive Madden for any amount of time, you know that building a strong defense is key to dominating your opponents. After nearly a decade of experience and a record of 203 wins and just 15 losses with an average of only seven points scored against me, I've figured out the most effective defensive strategies for winning games. In this article, I'll be breaking down the top five defensive coverages you need to master in College Football 26. Whether you're a seasoned player or just starting, these tips will help you win more games and get more stops on defense. Having a sufficient supply of CUT 26 Coins can significantly help you improve your win rate.
1. Cover 2 Man: A Must-Have Coverage
Cover 2 Man is essential for any defensive scheme. It's particularly effective when you're facing offenses with strong passing attacks, and it's versatile enough to be used in a variety of situations. I prefer running this coverage out of formations with at least five defensive backs, such as Nickel, 4-3-5, or Dime.
Here's how to run Cover 2 Man at its best:
Press Coverage: After selecting Cover 2 Man, press wire/triangle and push down on the left stick to ensure your cornerbacks are in press coverage. This will give you better jam and bump opportunities against wide receivers.
Shade Your Coverage: To help prevent wide receivers from breaking free, you can shade your coverage by pressing wire/triangle and adjusting with the right stick to shade outside or inside, depending on the route you expect.
User Control: A key part of executing Cover 2 Man is controlling the user player. It's important to be aware of who you're manning up against. For example, if the offense has a halfback out on a route, stay with him. If he blocks, you have more freedom to roam the middle of the field or even take control of a safety to cover deeper routes.
Two-Man Pass Rush: Pair Cover 2 Man with a two-man pass rush to apply consistent pressure while maintaining solid coverage. You can zone out one of the defensive ends (e.g., setting him in a hard flat) and add a QB spy to help keep the quarterback contained.
Cover 2 Man is a solid go-to for long-distance passing situations like third-and-15 or fourth-and-long, especially when combined with a strong pass rush and user adjustments.
2. Cover 4: Protect the Seams
Cover 4 is another defensive coverage that should be in every player's playbook. It's a pure zone defense that excels in defending the deep middle of the field and plays well against the run. Here's how to run Cover 4 effectively:
Press Coverage: Just like with Cover 2 Man, press wire/triangle and adjust the coverage by pushing down on the left stick to get better control of your defensive backs.
Safety Adjustments: The key to making Cover 4 even more effective is adjusting your safeties. Press the right stick in, then adjust the depth and width of the safeties to bring them closer to the line of scrimmage, helping to protect the middle and seams. This adjustment is critical when defending post routes or crossing routes.
Run Defense: Cover 4 also helps in run defense, especially when paired with a safety in a downhill position. By adjusting the safety depth, you can make sure he is in a better position to stop any runs that come his way.
3. Tampa 2: Classic Defense with Adjustments
Tampa 2 is a classic defensive coverage that's been a staple in video game football for years. While it's effective in certain situations, there are some adjustments you can make to optimize its use.
Use in Short Yardage Situations: Tampa 2 is great for defending against short-yardage passes (e.g., fourth-and-one, third-and-three). To enhance its effectiveness, shade your coverage underneath and ensure your middle linebacker is keying on routes in the short-to-intermediate range.
Coverage Adjustments: If you're facing deep routes or routes attacking the seams, Tampa 2 might leave you vulnerable. You can prevent big plays by making sure you shade your coverage underneath and pay attention to the middle of the field with your user.
Zone Drops for Long Passes: For long-distance situations (third-and-long or fourth-and-long), you can adjust your zone drops to cover the first-down marker. Set your flats to 15 yards and your hooks to 10 yards to prevent easy yardage.
Tampa 2 is a solid base defense when you know your opponent will rely on quick, short passes or when facing a short-yardage situation.
4. Cover 3 Cloud: A Hybrid Coverage
Cover 3 Cloud is a hybrid coverage that blends the best parts of Tampa 2 and traditional Cover 3, making it a fantastic coverage to use across different situations. Here's how to run it effectively:
Formation Flexibility: Cover 3 Cloud can be run from a variety of defensive sets, such as Nickel, 4-3, or Dime, and it provides excellent coverage for deep routes while still offering decent protection against the run.
Outside Third Safety: In Cover 3 Cloud, one of the key adjustments is that the high safety is in an outside third, which allows it to NCAA Football 26 Coins better cover corner routes while still protecting against bombs deep down the field. This setup improves the coverage on outside routes compared to traditional Cover 3.
Stellaol
Вернуться в Обучающие курсы по высокоэффективной жидкостной хроматографии (ВЭЖХ)
